N-Trouble's avatar
N-Trouble
Eternabond prep and install advice
I purchased a 50' roll of 6" wide to lay along the roof edge on each side of my 5er. You can see i have had a couple of incidents with trees that put a few quarter size tears in the rubber roof.
I hear prep and install is everything when it comes to laying this stuff down. My plan is to wash with soap/water then use some mineral spirits along the area to remove anything else.
As far as laying the Eternabond down you can see there is an arch in the roof line about 5' back from the front cap. Should I use two separate strips that meet/overlap at the arch or is the stuff playable/bendable enough to start at the front cap and run one continuous 25' strip down each side?
I've also heard its a good idea to take something like a rolling pin to it after installing to make sure good contact which I plan on doing.
Any other advice?
  • gbopp wrote:
    Spend the money and buy a roller. Eternabond sells one but, you can get the same thing cheaper on Ebay. I like the steel roller, some like the wood roller. They do a good job.
    I would probably use two sections for the arch. It will be easier.
    Maybe someone has a better idea for the arch area.
    2x on getting the roller. There is the mechanical sticking more like duct tape then there is the chemical bonding. It takes a lot of pressure to pop the chemical bonding properties (westend covered that well). We use acetone to clean.
    Eternabond typically comes off for two reasons over time. The surface had silicone on it or not enough pressure was used to trigger the chemical bonding.
    In direct hot sun in hot weather it will stick to itself fast after you remove the plastic film we found if not carefully. We started it and pulled the plastic film out as we hand pressed it into place then rolled with a lot of pressure.
    This is all covered well on Eternabond site. It is not hard but doing a short test strip in a place it is need can be helpful.
    IF you have to lap it on the edges of the roof because you run out of a roll we started from the rear so limbs would not find a catch edge.
    Just like cutting lumber we did the long runs first to reduce odds of splicing. It is awesome stuff.
  • Use acetone, and the surface must be very clean and dry. I found that applying a little heat helps in getting it to stick.
  • I also suggest using EternaCaulk along all the tape edges -- it prevents "tenting".
    I used the caulk on just some of my tape edges and after 2 years there's no tenting on those sealed edges. However, on the unsealed edges I'm getting some minor tenting.
  • For final cleanup, use Acetone or Alcohol instead of mineral spirits. ISTR, a poster stated that the Eternabond Preparation product is primarily acetone.
    You must use a roller with a good amount of pressure to break the encapsulated adhesive within the tape's matrix. Roll it good, using a small roller with handle.
    The tape should roll over that arch. Lay a piece of tape with the plastic backer still on before proceeding and see if it buckles too much. If warm out, I think the top vinyl layer has enough give to make the bend.
    Good luck on the taping, Eternabond is a great product.
  • TechWriter wrote:
    Don't stretch it! Just lay it down.
    This is great advise. Also do the job when the roof is warm. It helps the sealing processand you definately need the roller to insure a good seal.
  • Spend the money and buy a roller. Eternabond sells one but, you can get the same thing cheaper on Ebay. I like the steel roller, some like the wood roller. They do a good job.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
