3940wez12's avatar
3940wez12
Advice for inverter installation
I'm adding a 600 watt inverter and the plan is to put it in the pass thru storage compartment, which will be just behind the batteries on the trailer tongue. My first inclination was to run the cables under the front of the trailer and cut a hole in the floor but to do that I'll have to also cut into the plastic stuff (not Coroplast, kind of like a plastic tarp) completely covering the trailer's underbelly. The more I think about it, the more I worry about being able to completely seal up even a little hole once the cables are passed thru. I think I've seen where someone drilled thru the diamond plate on the front and avoided the underbelly altogether. If so, what kind of junction box, bushing or whatever should I use to run the cables through?
Any advice would be much appreciated by this lady "senior citizen" before I go cutting holes in my TT.
