TheWanderer's avatar
TheWanderer
Ford 460 engine questions/issues
Hey everyone, new to the forums and new to RV ownership. (Owned about 2 months now).
Firstly, HI! nice to join a community of like minded travelers!
I own a 26 foot 1988 ford gulfstream rv.
Ok so I am doing a fairly major overhaul on the Ford E350 v8 460 block engine. It has had a handful of things replaced already (starter, map sensor, pcv valve and tubing, spark plugs, etc etc.) and now I am working on lifting the engine to access the oil pump and crankshaft bearings. I just had a couple things I have run into I am unsure on.
Firstly, does anyone who has done work on this engine have any further tips for oil pan removal?? I have never had to go through so much just to get the dang oil pan off on a vehicle! The frame is 1 inch below the 7 inch deep oil pan. So in order to get the pan off and around the oil pump and crank and such, I have to lift the motor at least 5-6 inches. That meant removing a LOT including the throttle body, which leads me to my second question.
I cannot seem for the life of me to find a matching replacement for my bottom gasket for the throttle body, where it mounts to the engine. I will try and link a photo of it to show what mine looks like, but i cannot seem to find a replacement anywhere! It flaked some upon removal of the throttle body.
Thanks in advance for any advice or help!! I am quickly learning a LOT about this engine and RV with all the work i am doing. (I was basically scammed in purchasing a used RV. Tip for others/the future, GET SOMEONE TO INSPECT IT FIRST!)
Hope y'all have a great day, happy trails!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
