westend's avatar
westend
Ford Superduty battery and charging issue
Yesterday, I had my small utility trailer on the hitch of my 2003 F-250. I had dropped the trailer off and then put it back on the ball. Since it was near nightfall, I checked for running lights on the trailer. No luck. I messed with the 4X connector for a bit and finally gave up, choosing to leave the trailer until daylight. On the way home, the battery indicator and ABS indicator lit up on the dash display. I stopped the truck to inspect and barely got it restarted. I made it another two miles and the truck would not run.
This morning, I went back to truck with a fully charged battery, installed it, and made the 5 mile drive to home. All indicator lamps are now off but measuring across battery posts with engine running, I'm seeing 12.3V.
All symptoms point toward a failed alternator but this charging system has been flawless for 11 years. Is it possible that I blew a fusible link or some other circuit interruption instead of a failed alternator?
Anyone have any diagnostic tips for me?
Having RV issues? Connect with others who have been in your shoes.24,355 PostsLatest Activity: Jan 31, 2026
