allaue87's avatar
allaue87
Explorer II
Apr 26, 2026
Ford V-10 6.8L Seized Lost Oil Pressure
Hello,
I am making a post to share my experience in case any one is searching and looking for advice.
I have a 2015 Class C RV on a Ford E450 chassis with the V10 Triton 6.8L engine. The vehicle only has 21,000 original miles on it and we have done about 3 years of trips on it no problem. I did an oil change only 1,000 miles ago at the most & the oil level looked fine, used Ford Motorcraft oil filter as well. We bought it with 17,000 miles and it ran just fine - no concerns, well maintained.
I was about 100 miles into our next trip and gauges looked fine and all that. I was driving up slight grade at 5,000 RPM and next thing I know, the gauges catch my attention. Oil pressure had dropped to 0, the oil light was on, and it started to rev down to a complete stop within 60 seconds. Nothing sounded strange, just the engine revving down through the gears. The battery, fuel, coolant gauges were reading normal, but oil pressure was 0. I go to start it again and the starter was engaging but not turning over. We got towed up a little bit to a safer spot to troubleshoot more. The next day, I got a 18" breaker bar and an 18mm socket on the crankshaft pulley to try to turn it over by hand. It was stuck. I let up tension on the belt and all the accessory pulleys spun freely, so it's not a locked up accessory.
Anyways, justing posting here for ideas and anyone else who does a frantic google search like I did the past 48 hours to dig as much info as possible. From what I read from other posts, it looks like if it is seized, an engine swap is needed. I was going to drain the oil and check for metal / shavings. Before I start pulling it, are there things I can do in the disassembly process to check out? One major problem is that I can't turn it over to separate the flexplate from the torque converter. What would I do from there if I cant end up separating it? My engine hoist is rated for 2 tons.
  • sounds like a fram filter was used.......the "fibrous" material is prob one for their flimsy cardboard end caps they use in manufacturing, and their anti drain back valve is junk too.  Other cheap lines of filter previously used could have failed internally, sending debris into the pump
    • allaue87's avatar
      allaue87
      Explorer II
      Yes, I do believe it was a Fram. It was 15 months ago or so, but I vaguely remember that distinctive orange/black filter on it. Bummer.
  • Here's an update after the teardown and some history.
    I bought the RV with 17,000 miles on it. Did an oil change around 19,000 miles with OEM Ford filter. I don't recall what brand was on it before, but it wasn't OEM. The engine seized at the 21,000 mile mark.
    As you see in the pictures, the first four pistons were heated to black and were seized to the crank shaft. The oil sump filter is clogged with a fibrous material - which I am thinking is it filter media. If so, that might have been the issue & caused the oil starvation. Then it started eating away at the bearings and sending metal material to the oil pan.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Dammm Fram strikes again it appears.
      Have heard all about how Frams are supposedly improved in the last (however long), but I saw it first hand a long time ago thankfully on a small engine (2 cyl mower engine) and that was enough to never buy an orange colored oil filter again.
      Doesn’t help and appears it wasn’t you who used one. There’s also the possibility that being an older used RV with super low miles that the previous owners didn’t do regular maintenance. Given it likely had very few or zero miles per yer for a Buncha years.
  • Here's part 1 of my update -
    I got to work on it this weekend. I drained the oil and there was close to 6 quarts and there was a slight metallic haze to it. No big chunks or anything catastrophic looking, but definitely a small amount of shiny particles floating on the surface. The oil filter was practically dry - I spun it off and turn it over, just a few drops. I got the whole front end off but had to call it a day. The RV is 90 minutes away from me at a family property, so I think next time, I will be able to pull the engine out and get it on a stand.
    • allaue87's avatar
      allaue87
      Explorer II
      I think at that point, I was only doing it for maybe 1-2 minutes max. When I am in tow/haul mode it decides whether it wants to do 3k RPMs and sometimes it will bump up to 5k RPMs even if I am putting the gas all the way down. I thought it was all electronically controlled? I haven't picked up how to "decides" to do 3k or 5k - it will sometimes just go to 5k for a little bit then settle back down. I'm guessing it switches between the two top gears on the A/T?
  • That’s a **bleep** shame, and not a common failure. Triton platform engines spanned about 15 years in all the pickups and longer in chassis cab models and were not prone to low or high miles oil pump failures. And tons of them high miles still working daily at 10-30 years old.
    Im presuming oil pump since your post alludes that the oil didn’t leak out or get contaminated with coolant.
    At this point, be thankful this is a diy job for you (presuming since you actually have an engine hoist) and just slap a reman or low mile junkyard long block in it and continue to be perplexed why you drew the short straw and lost the engine at extremely low miles.
    • allaue87's avatar
      allaue87
      Explorer II
      Thanks for replying. Yes, I am thankful I have the tools and ability to pull & replace. I do want to tear it down to figure out went went wrong. It really is a short straw - I saw these engines can go very high miles so 21,000 was practically new.
  • 60 seconds is a long time with no oil pressure.  at any rate your going to have to pull it to figure ou what went wrong and see if it needs a new motor or just new berrings.   if you can't get the flexplate undone pull the motor and trans out as one peice.  I don't think I would ever concider spliting a motor and trans in the truck unless it was just the trans I was taking out.
    did you idle it a lot?  we use truck with this motor at work and got rid of them because our truck pretty much 24/7 and are ideling that whole time and they have an issue with low oil pressure at idle and we were going through campshafts and berrings left and right.  for anormal person this isn't an issue, but there is a chance a rv might run into somthing like this if you idle for extended periods of time to charge batteries or what not.
    • allaue87's avatar
      allaue87
      Explorer II
      Thank you for the reply - we did not idle a lot. It was actually continuous driving a solid 2 hours. The grade I was on was about 3% but it was off and on from flat to 3%. Definitely was not overheating or anything like that. I'm still clueless as to why it would just fail.
      • StirCrazy's avatar
        StirCrazy
        Moderator
        with the ideling I am not talking about that trip, I ment over all since it was brand new. its the 17000 miles that were on it that you don't know about.  it could have been driven for 17000 miles but idled for 1500 hours.  but like my daughters car this week 😒 a sudden drop in oil pressure can be cause by a few things, oil pump failure, bearing failure and so on.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
