RJN's avatar
RJN
Fuel pump ?
My 1999 Gulfstream Triton V10, starts right up idle straight runs up good I drive around the block a couple times to warms up with my pressure gauge hooked up and it drops from 32 psi down to 10 when i acceleration , dinner idle it back to park it shut it off and after 3 or 4 hours I started up again and same thing happens every time I change the filter a few times I drain the bad gas out of there thinking that was the issue but the same symptoms just looking for some feedback before I drop that tank would it be something that simple as a relay which some people say I guess I'm hoping for but it sure seems doubtful but I ll definitely check that
  • I have been watching this one, I don't think it is a screen getting plugged, because as soon as you shut it off or after a bit when the fuel pump cycles it would clear its self.
    but you mentioned you changed the fuel filter and it still does the same thing.  to me the next logical place to look would be the pump its self.  having said that it could be the relay for the pump or the pump they have similar fail modes.  if the relay is cheep, change it and see if it works, if not find a new pump, or go to a different style pump like way2roll mentioned.
  • Based of above, I would be pulling the tank next if it was mine.
  • It sounds like it's picking up debris in the tank and plugging the pickup tube.  Whether it be the sock or dirt.  After the 3-4 hours the obstruction drops back out.  I had an old tractor that did this once.  It had an oil bath air filter.  Come to find out it had never been cleaned before I got it.  it would run 10-15 minutes like a champ then die.  I thought it was the fuel pump  i tried everything then i took the boot to the air filter loose for something and started it up and it ran like a champ.    That's how i found out about the oil bath filter.  but it does sound like you have an obstruction somewhere.  Good luck!
    • RJN's avatar
      RJN
      Thank you for the reply, that would make sense to
  • Yeah thanks for the feedback unfortunately it isn't a tank
  • You're definitely right that it's most likely not the relay but I would definitely check all the easier stuff before dropping the tank. Personally I would see if I can get the meter hooked up as close as possible to or all the way back at the tank. Then take a voltage reading when you have 32 PSI and when you have 10 PSI. Alternatively find a way to provide supplemental 12v power to the fuel pump. I'm betting the voltage doesn't change regardless of the fuel pressure in the system.
    You say that the pressure drops from 32 to 10 PSI under acceleration. Is that under any acceleration or just heavy acceleration?
    You said if you shut it off for 3-4 hours it behaves the same as above. Have you tried waiting until it's at 10 PSI then turn the motor off and right back on? Does the pressure revert back to 32 PSI or is it still at 10 PSI? does the system need 3-4 hours to regain the 32 PSI?
    Ultimately if I had to hazard a guess I'd say your fuel pump is on it's way out. Or at the very least the pump pickup sock in the tank is plugged up. They are available on Amazon.
    • RJN's avatar
      RJN
      Thanks for the feedback at first I thought it was bad feeling I did drain all the fuel out and I put on like 10 gallons of good fuel and seafoam and a couple new filters but nothing changed  it'll just start losing acceleration after it warms up a couple trips around the block we're I keep my motorhome.
      Let it sit for a while and exact same thing happens. I suppose even if it is that suck tanks got to come down regardless if I got that lucky
    • way2roll's avatar
      way2roll
      Trailblazer
      Was the fuel pump for that year in the tank? I had a similar issue with my old Jeep and didn't want to drop the tank. I put an in-line fuel pump in and solved the issue.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
