hammick's avatar
hammick
GC2 batteries: help me pick power supply for maintenance
Hello all. This is my first post here. I have read till my head spins the Megawatt and CPS-1620 charging threads. Read the 40 page maintenance thread. Lot's of great information you can't get from the manufacturer.
I'm looking for advice on purchasing the CPS-1620, Megawatt or this on Ebay:
Ebay power supply
On my Toyhauler I have two new Interstate GC2-RD batteries in series (the Costco golf cart batteries). 208ah. Most of our camping is boondocking. I have the built in Onan 4000w generator and build in 160w solar panel. I am changing the solar charge controller to a Blue Sky Sun Charger 30 that I can adjust for specific voltage and absorption time. My converter for now is the WFCO 55a that won't go into bulk mode. I may upgrade that to the PD with the charge wizard if I find the solar isn't getting the batteries fully charged.
I have a decent voltmeter and hydrometer. I am going to buy the Freas hydrometer recommended by MexicoWanderer. I will also by a clamp amp meter and probably install a Trimetric monitor.
I want to get a power supply so I can fine tune my batteries. Top off charges and equalization.
I want these batteries to last but my main objective is to learn how to properly maintain real deep cycle batteries for down the road in retirement when I will have an off the grip home with a large and expensive battery bank.
Interstate recommends a c/10 charging rate for my batteries which is roughly 20amps. I believe MexicoWanderer recommends a 5% of total ah rate (c/20) for top off and equalization which would be closer to 10 amp.
I'm intrigued by the CPS-1620 for it's small size. However, from my experience heavier is usually better in the electronics world (at least with audio equipment). The Ebay supply weighs 6 lbs 2.6 lbs for the CPS-1620
Thanks for any advice.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
