unioncreek's avatar
unioncreek
Generator doesn't run at constant speed?
I have a Champion 4000 generator that I use to run the AC on my fifth wheel. It doesn't run at a constant speed unless I have the choke just slightly closed. I cleaned the carb, lines and tank. But, it still runs that way. I noticed that you can put the long spring on top of the carb in different holes would that change anything. I runs fine otherwise and will run all day long with the choke closed slightly.
Anything else I should look at?
Bob
  • I suggest trying some Seafoam in the gas. I use a combo of Seafoam and Lucas injector cleaner to keep my carb clean.
  • dave17352 wrote:
    I am sure you are aware that when the load changes the speed will change correct? just checking
    Huh? :h Assuming the OP's genset is a synchronous model and not an inverter model which does vary speed according to load then it should run at a constant speed of 3600 rpm ... after all, that's how a synchronous genset derives it's 60 Hz frequency, unlike an inverter model in which the inverter itself creates that 60 Hz signal regardless of engine speed. If this is indeed a synchronous genset that is varying in speed then it needs servicing.
  • I'm thinking you still have something in the carb. I have had to clean a couple of small engines several time before I finally got it right.
    Wayne
  • Matt,
    I'll try lubing all the linkages. I've had the carb apart a number of times and soaked in carb cleaner, cleaned all the passages and blown them out with air.
    Bob
    Matt_Colie wrote:
    It is probably lean. Unfortunately, this may not be adjustable so you may have to go into the carburetor again and clean the main jet and related passages.
    Matt
  • It is probably lean. Unfortunately, this may not be adjustable so you may have to go into the carburetor again and clean the main jet and related passages.
    Matt
  • Have you cleaned and lubricated, if needed, the linkages between the carb and the governor? Friction in that mechanism could lead to hunting, particularly under light load.
  • Yes, I understand that. When I turn the choke all the way off the rpm's fluctuate up and down quickly.
    Bob
  • I am sure you are aware that when the load changes the speed will change correct? just checking
Having RV issues? Connect with others who have been in your shoes.24,279 PostsLatest Activity: Jul 04, 2025
