unioncreek's avatar
unioncreek
Generator doesn't run at constant speed?
I have a Champion 4000 generator that I use to run the AC on my fifth wheel. It doesn't run at a constant speed unless I have the choke just slightly closed. I cleaned the carb, lines and tank. But, it still runs that way. I noticed that you can put the long spring on top of the carb in different holes would that change anything. I runs fine otherwise and will run all day long with the choke closed slightly.
Anything else I should look at?
Bob
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
