Land_Yachters's avatar
Nov 01, 2020
GFCI outlet is popping when I plug in coach
So, picked up our Tiffin 33aa from dealer for some various service issues. Went home and plugged in to same outlet I have been plugging into for a year outside. A 15 amp, exterior GFCI outlet that I just use for charging the batteries. I typically turn charger off when I plug in because I figure it’s a good idea to limit variables. I typically hear a “pop” at the surge box and then turn on charger and hook up trick L start for chassis battery. Today, as soon as I plug coach in, the outlet GFCI from the house pops. (the outlet I plug into outside). I checked power at outlet, extension cord, charger setting etc. and plugged in again. POP, the GFCI pops every time I plug coach in. Turn off batteries, check outlet with hair dryer and nothing I do can keep the outlet from popping. Start generator…all good. See GFCI in coach in bathroom popped. OK, I reset it thinking somehow that had something to do with issue. Shut generator off and plug in again. GFCI pops again that I am plugged into. (Also, GFCI in coach pops.) OK, I turn main 50 amp breaker in box OFF, thinking I could turn on circuits until I find one that pops outlet. Still, the outlet GFCI I am plugged into pops. I check charger/inverter breaker and it’s ok. No breaker on Surge Gard.
What am I missing?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
