RDMueller's avatar
RDMueller
Got a new Toy! PowerMax Boondocker adjustable 60A
Add me to the list of those who are putting aside the automatic "smart chargers" and going with something manual! I've messed with the on board Wiffco, a Battery Tender, various wall warts and the crazy Schumacher, learning as I go. Now I've finally found something that I think is going to work great (Thank you BFL)!
Fully adjustable up to 15.5V, but unloaded it gets pretty close to 16V. So it should be good for regular charging and equalizing. Maybe a little low for desulfating, but hopefully if I take good care of my batteries, I won't need to desulfate. Plus, for under $30 I can add the Drok boost voltage converter to the mix (Thank you Mex), and adjust the amperage as needed. At 60A, I can do a quick charge off the gen when dry camping, then when I get home, I can charge at C/20.
Now the only thing I haven't decided yet is whether or not to add an ammeter. It would definitely be useful, but I'm thinking I can get basically the same info by plugging the Boondocker into the Kill a watt.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
