wa8yxm
Jun 09, 2021Explorer III
If the test button trips the GFCI when the breaker is ON the GICI is working
If the breaker is a Trip-o-matic then either there is a short (hot to neutral) over load (Too much stuff plugged in) or the breker is bad
Some breakers are designed to trip if you touch them.
UNPLUG everything. see if the breaker holds. then start plugging stuff back in one item at a time.
True story
Camper (Nice Class A) half his outlets were out.
I ask if he had an inverter (he did not know
Had a nice Tripp-Lite
Viewed from above the breakers looked like this \/ Made 'em look like this // and all was good.
True story
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
