pryoclastic
Nov 19, 2017Explorer
So our trip to Colorado was mostly uneventful and the kids had a good time which was the intended goal. I also really appreciated the feedback and comments. Thanks!
Prior to the trip I did get a call from HWH and spoke with a very knowledgeable person and he ended up recommending the replacement of the actuator. As of yet I have not ordered a replacement because I noticed an odd quirk during my final pre-trip checks.
When I deploy only the rear jacks, (which is the original fault that started this thread) the passenger side fails to rotate but it will extend. However. If I deploy only the passenger side (front and rear), the rear passenger jack will rotate and extend as expected without issue.
Do you think that the actuator should still be replaced or should I be looking another part of the system or is this generally considered normal ops?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
