rjf7g
Jan 01, 2014Explorer
Honda EU2000i pulling too much fuel from extended tank
I rigged up a marine tank to extend the run time and the generator is sucking too much fuel since I pulled off the cranky primer bulb and it will actually overfill the on board tank. I got a new primer bulb to install and I will see if that helps. It worked fine for YEAR but the needle in the primer bulb started sticking. What else would you consider or check?
