- HuntindogExplorerThe motor has 20% more displacement, and is a heavier duty one.
That makes it VERY likely that it will easily do the new specs, and last even longer than the previous ones... It is not just a "fluff" upgrade.DrewE wrote:
pnichols wrote:
That 2200i spec for it's noise at full power (62 dB) - an increase over that for the 2000i - is NOT insignificant!
What would have been a really outstanding engineering coup for Honda would have been if they could have kept it's maximum power level noise no greater than that for the 2000i -> 59 dB. Note that the common RV 4000 watt Onan built-in gas generator has a noise spec of around 66 dB "out in the open" as delivered .... but of course they are enclosed inside RV cabinets which can make them considerably quieter than 66 dB, as heard from the outside .... probably will below 59 dB in most RV installations.
Honda did keep it's weight about the same as the 2000i, however ... which is commendable.
It makes me wonder if maybe it's the same basic generator as the 2000i, just with modified control circuitry (and maybe an improved inverter) so that it will output more power, of course running the engine at a higher speed when it does so. If that's the case, then it should be about the same loudness at equal loads. - ROBERTSUNRUSExplorer:) Hi, finally an update, but not enough. Honda should have at least matched my Yamaha 2400.
- DrewEExplorer II
It makes me wonder if maybe it's the same basic generator as the 2000i, just with modified control circuitry (and maybe an improved inverter) so that it will output more power, of course running the engine at a higher speed when it does so. If that's the case, then it should be about the same loudness at equal loads. - ktmrfsExplorer II
BFL13 wrote:
The blurb talks about watts, but the old one used VA, which is better for figuring what it can do. Assuming the new watts is VA then this one will do 1800VA instead of 1600, which is better. No way to know if it can run whatever you have without knowing the PF of your appliance and its rated input watts.
I'd bet that the new spec's are indeed VA not watts.
But as I and someone else mentioned, the extra 200VA may take it from "almost adequate" to "barely adequate" for some applications.
My 2000 will easily start my coleman Mach III with the micro air easy start at even 4500ft elevation at 90F. But it will only run for about 10 minutes before it overloads. I'll be the extra 200 VA would get me over the "hump". and mean I don't need to parallel at higher altitudes.
But then I already have 2 hondas, why get another? - BFL13Explorer IIThe blurb talks about watts, but the old one used VA, which is better for figuring what it can do. Assuming the new watts is VA then this one will do 1800VA instead of 1600, which is better. No way to know if it can run whatever you have without knowing the PF of your appliance and its rated input watts.
- SidecarFlipExplorer IIIAs an aside, I did have one Honda motor blow up on me a year ago. Tossed the rod through the case. Was a GC motor (overhead cam, belt driven) and I suspect a rod bolt was not tightened. Honda would nor stand behind it so it went in the garbage and I replaced it with a Predator and it's been running ever since (on a pressure washer). The Pred was less than 100 bucks OTD.
Things happen with mass produced stuff. - SidecarFlipExplorer III
theoldwizard1 wrote:
It is about time ! Honda has been resting on it laurels for a long time.
This does use a new engine that is designed for HD, long term usage.The GXR120 engine includes a special cast-iron cylinder sleeve and a high carbon-steel, dual-ball bearing crankshaft that provide improved engine strength and lasting durability.
They continue to MISS THE MARK by not offering a version with a TT30 outlet (the Companion version still has a (twist) locking plug)
If Champion maintains the quality of their product, Honda will have to get more aggressive on their pricing. The cost of the electronics have dropped to a fraction of what they were when the EU2000i was introduced.
...and are more reliable as well...
I'm 4 years into my Champ with ZERO issues. I haven't even changed the plug yet Stars first pull everytime but then so does my Honda tiller and both my quads. Far as longevity goes, my one quad is a 1994 Honda Foreman 400 and it runs like a top. Of course I do maintain it. I plan on keeping it until I die... Estate sale thing.
Didn't know the Honda didn't come with a fuel shutoff until now. The Champ has 2 fuel shutoff's. One on the carb (accessable from the control panel) and one on the gas tank fill. I always run the catb dry when storing and pull the float bowl drain to get every last bit of swill gas out. - theoldwizard1Explorer IIIt is about time ! Honda has been resting on it laurels for a long time.
If Champion maintains the quality of their product, Honda will have to get more aggressive on their pricing. The cost of the electronics have dropped to a fraction of what they were when the EU2000i was introduced. - dewey02Explorer IIPerhaps this is the only way Honda can remain competitive in a market where generators sell for hundreds of dollars less.
Personally, I would consider an improved Honda to be one that is at a price point where I could actually feel good about spending that amount of money.
Rather than lower their price, they add some watts. That's fine. I'm sure the Honda club members will be happy. It doesn't make a convert out of me. - GordonThreeExplorerAt least Honda offered a token 200 watt bump. Yamaha doesn't claim any increase with their v2 inverter, just that new software will handle more demanding loads.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
