GordonThree's avatar
GordonThree
How did you install your Garmin camera?
Garmin BC20 "Wireless Backup Camera"
The power cord coming from the transmitter box is super long, but the non-weatherproof fuse holder and camera connection are short. What's up with that?
I figure I can cut out the cheapo fuse holder and solder in a weather proof one. The camera connection will get a good dose of dielectric grease and then some self vulcanizing tape.
My trailer is all aluminum on the outside, roof included, not friendly to radio signals. I'm thinking I want the camera centered up high on the back wall... I can run the power cord down my gray tank vent along with the gps, cell and wifi antenna cables already installed.
The transmitter, depending on length of the camera's cord, could go on the front of the A/C shroud. If that doesn't work, I can stick it on the vent pipe, facing toward the front of the trailer. It won't have line of sight to the truck, the aluminum roof will be in the way, but maybe enough will spill / reflect to make it work.
Ideas?
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Chuck_thehammer wrote:
    I went thru this with my BC-30 2 months ago. power is from the tail light. camera mounted below rear window of trailer.. about 7 feet high.
    trailer is 30 feet fiberglass type.. not metal.
    worked poorly.. and screen refresh was very slow.
    needed to get the 50 foot extension cable ($30.00).. mounted transmitter under the propane tank cover. and power again is from tail light wires near front battery area. camera itself was NOT moved.
    worked very well and refresh is fast.
    and Garmin is mounted on top of dashboard.. both the 2597LMT and 770LMTHD units.
    truck is F 250 supercab long bed.
    sounds exactly like what I did. works perfect. In fact that is why garmin has the extension cable. get the transmitter right near the tow vehicle.
  • Mine's the BC-30 but I assume pretty similar. I also purchased the extension. I installed mine on a truck camper so I drilled a hole through the wall above the back door and ran the wire inside, from there I hooked to the extension and ran the transmitter up to the front to be as close to the truck as possible.
    I then wired it in to the 7-pin plug to get power when in reverse. I also wanted to be able to turn it on at will so I ran a wire from one of my upfitter switches under the truck and back to a disconnect where it goes into the camper. I also had to install a diode on the reverse connection so that it wouldn't back-feed the backup lights when i turn it on via the upfitter switch.
    It's worked great for me this way and I get great reception but of course with a truck camper the transmitter is only a few feet away from the gps device.
  • Good to hear there's an extension cable. If if plan A and B don't work, I can extend the transmitter up to the front and stick it on the fiberglass nose window cover, I have a large 12v electrical junction box near by to source power from.
  • I went thru this with my BC-30 2 months ago. power is from the tail light. camera mounted below rear window of trailer.. about 7 feet high.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
