AllegroD
Sep 19, 2015Nomad
smkettner wrote:
Second battery should make it easy and a lot less $$ than a Honda 2000.
I'll help spend your money. Get both. As Mex pointed out, there are a lot of things to consider and I was estimating 3 AM. Then after a few recharges it will be 2 AM, then 1 AM, as the battery now is and will not fully recover. Draining below 50% will kill it early.
And as someone pointed out, cold days and not being able to run the genny all night will make things immediately worse and as someone else pointed out, if the pipes freeze, it is immediate disaster.
You are in a cold land.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
