Jfresh's avatar
Jfresh
Single Battery Enough?
Last night it was my first time using my 2015 Lance 865 dry camping. Single factory battery setup. I keep the camper plugged in at home and the truck charges the camper battery. Pulled into our site before dark, switched fridge from battery to propane and lowered my atwood jacks. We sparingly used the led interior lights until bed and set the furnace as the lowest setting. It was probably 30 degrees overnight. I would say the furnace kicked on once every hour. Woke up and turned the furnace to 60 until the camper warmed up and kept at 60 for an hour or so then turned it off after breakfast. Went out after breakfast to raise the jacks and it was a no go. Started the truck and they would go little by little every 5 minutes. In addition my remote would turn off every time the jack stopped raising. So either my battery was dead or my remote needs new batteries. Ended up raising the jacks by hand. Can a single battery drain enough overnight to where the jacks won't raise? I will also try new batteries in the remote. Should I start thinking about adding a second battery?
