S_Davis
Apr 27, 2020Explorer
How many Ah
I need a battery bank to power a mini fridge 1.3 amps @ 120v for 48 hours and a electric blanket 200 watts @120v 8 hours as well as computer and cell phone charging, how many Ah will I need?
full_mosey wrote:S Davis wrote:
Ok so I changed direction, I bought a ARB 50 quart fridge freezer, it draws .87amps @ 12v and should be adequate for the amount of food I need for two to three days.
AFAIK, that ARB has a 12V compressor motor of the Danfoss design(Now owned by SECO). It is a fine fridge.
I have a similar 50 quart ICECO JP50 with the SECO compressor. The running Amps on that compressor are from 5 to 4 Amps according to the specs and my clamp on meter.
The .87A must be an average draw at a particular ambient temperature. You can also confirm this by running the ARB on 120VAC through a Kill-A-Watt.
S Davis wrote:
Ok I ordered the 75amp PowerMax and two double GC2 battery boxes.
BFL13 wrote:
Note the Trojan charging spec for 14.8v (at 77F--higher when cold out) and occasional equalizing at 16.2v. Note my previous post re the PowerMax LK, which can do that 16.2 when needed. Good luck finding any other converter that can do that! :)
Can't understand paying $170 for Trojan instead of $90 for Sam's/Costco when on a budget, but you are over 21 so not my business.
