Gjac's avatar
Gjac
Explorer III
Jul 13, 2014
How to check a refer cooling unit for blockage
Every year I read a lot of posts about clogged cooling unit tubes. Every year when my 18 year old Norcold 682IM is above 40 degrees in the refer compartment I wonder if it is getting clogged. It was 90 degrees the other day and I was shooting the tubes and boiler in the back with my HF IR temp gun looking for cold spots, thinking that this would be a blocked section. Is this a way to check for blocked sections of tubing? I don't know what temps the tubes or boiler section should be at for optimal cooling. Also I was thinking if you knew what the optimal temps should be at for various sections of the refer cooling unit I would think that by taking temperature readings at certain reference points this would be a better way to level the unit assuming that the lowest temp is the best condition, and once you find the lowest reading then set a bubble leveler inside the MH to match this lowest temperature reading. Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
