Vulcan_Rider
Nov 02, 2015Explorer
LynnandCarol wrote:
OP Update.. Tested my battery (2) both had 12.6 DCV. Then tested the trailer battery lines and got 13.5 DCV. Removed covering from junction box and no fuse or any other inline fuse on the external wiring. so not sure where to go from here??
Some may understand what you are saying but most probably not.
You need to be a bit more specific.
Which two batteries did you test ?
What was running when you did the test....truck engine, generator or shore power ??
And where exactly did you test the "trailer battery lines" ??
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
