time2roll
Nov 02, 2015Nomad
LynnandCarol wrote:13.5 would be a normal float. 12.6 is fully charged but not charging.
OP Update.. Tested my battery (2) both had 12.6 DCV. Then tested the trailer battery lines and got 13.5 DCV. Removed covering from junction box and no fuse or any other inline fuse on the external wiring. so not sure where to go from here??
How many sets of batteries do you have? All batteries should be at 13.5 if you are plugged in. Measure on the actual battery terminals, not the wire, not the clamps, not the fuse.
Until now I had thought this was a motorhome....
Do you have a storage switch that was turned off?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
