Bounder_Lew's avatar
Bounder_Lew
HWH 325 leveling jacks manual problem
I have a neighbour with HWH 325 jacks which do not have the level sensing system. He is blowing the 15 amp fuse for Right Front and Left Rear when operating the jacks. We got right rear to go down with a new fuse, but when attempting to bring the jacks up the fuse blew again. The jack came up a bit and stopped. The Right Front Jack did not move but even though it is fully up the Lowered warning light and horn is on.
I have the trouble shooting manual but the fault is not explained.
I am thinking the problem is in the control box.
Out of interest, the hydraulic solenoids for the jacks that work seem to get quite hot when they are released, ie jacks raised to up position.
Left front is too hot to touch until a few mins after retracting.
Any suggestions would be appreciated.
  • For those interested I found some good information here:
    http://www.irv2.com/forums/f101/problem-removing-hwh-solenoid-72695.html
  • Thanks Chuck: I assume you just screw the solenoids out of the manifold? Of course with the jack up and the power off.
  • Bounder Lew wrote:
    Thank you very much Doug. I think you have pointed us in the right direction and indeed your statement that you should not leave the system on for more than 10- 15 mins and our experience at the heat in the solenoid (the one that completely failed has indications of extreme heat as the paint has pealed on it) is clear evidence of leaving it on too long.
    The situation which prompted him to leave it on too long was the fact that once the solenoid failed completely the jacks down light stayed on continuously on that jack- so he disconnected the horn and left it on to see if the jack down light would go out.
    And that brings up another question. Why is the jacks down light still on with the fuse blown and the Jack fully up? There are wires to the top of the jack which I assume go to a micro switch. Is it possible that the micro switch has failed?
    Thanks again for your help.
    Turn on the Dash Touch panel. That will indicate WHICH jack down light is on. Go to that jack and disconnect the down sensor at the sensor multiplug. That will turn the light OFF. If this works replace the sensor IF the jack is fully retracted. If NOT, then the wire harness is shorted somewhere between the jack and the control board. Doug
  • The wires on the top of the jacks goes to a magnetic switch, the jacks get down about 1/2 inch and they go on. More then likely the solenoids are not staying open so the springs can lift the jacks completely. Try opening the small nut between the wires on the solenoid with a 1/4 inch socket. do not turn it more then about 3 full turns though. That should let the springs return the jack fully, and turn off light. The solenoids are easy to change but expensive to buy, about $180 each from HWH. If the jacks don't go up with just the springs you can try prying them up with a two by four while you have the valve open. Besure to close valve when they are retracted to keep them up. Good luck
    Chuck
  • Thank you very much Doug. I think you have pointed us in the right direction and indeed your statement that you should not leave the system on for more than 10- 15 mins and our experience at the heat in the solenoid (the one that completely failed has indications of extreme heat as the paint has pealed on it) is clear evidence of leaving it on too long.
  • The solenoids are the culprit. They are shorting out. The solenoids are NOT continous duty solenoids. IF they stay on longer than 10 to 15 minutes, they overheat and short out internally. The fact that the other solenoids get hot point to that at some time the system was left ON in retract for more than 15 minutes. That will happen when one or more jacks do NOT fully retract and the system will stay on until the jack is retracted or you shut the system off. You really need to replace all 4 solenoids. The ones that get hot but function will fail in the future. THAT is why the fuse blows---it PROTECTS the Main control board system. Doug
