Racorman
Jul 22, 2015Explorer
Installing (6) 6volt Batteries - Is My Wiring Diagram OK
I previously posted a question regarding installing (4) 6Volt batteries in my 30’ class A MH…..smkettner was most helpful in dialing it in to make it work. I come back to the forum for additional help after spending 2 weeks in the boondocks. I found that I needed more battery power.
After sizing up all the places to put as many 6Volt batteries as I can, I found that I could actually install a total of (6) 6Volt batteries in the coach. There are 2 separate battery compartments 6 feet from each other. One holds (2) 6Volt batteries the second holds (4) 6Volt batteries.
I’ve put a wiring diagram together and hope that the system is balanced the way I have shown. Is there any problem or advantage in grounding the system at 2 separate distant points #14 and #15 (approx. 6 feet apart)?
Again, many thanks for those who know their stuff!
