Bemota's avatar
Bemota
interior lights
I'm having an issue with myinside lights. They ramdomly go from dim to bright. I have a WFCO 55 amp charger, that goes from 14.3 to 13.2, on a 1 minute cycle. I'm on 50 amp shore power at a campground, my EMS tells me that I'm drawing 118-120 volts and about 10 amps on each leg. Other than the coach lights, furnace and etc. I have a 12V electric cooler in the basement for DW's insulin. I think the charger is going further south then I am, thinking about replacing it, should I go to a 65 amp or larger? This is a keystone cougar 2011 326MKS I got used last May. I have 2 12V batteries that run everything for over 4 hrs when I turn the converter off. Should I stay with WFCO ? Whats better, any help would be great. Thanks, Dan
Sorry for so long !!!
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
