AH64ID's avatar
AH64ID
Inverter Power or Juicer Issues...
My wife has a Juicer that was sometimes take camping, it's has a simple low-off-high switch and a 850W motor, and runs fine off the Honda 2000 Generator and shore power.
My mom has the same juicer and it wouldn't run on my dad's Honda 3000 or Honda 5500 generators so he installed a Xantrex 1500w inverter and it works flawlessly. Still don't know why it wouldn't run on either of those, only the 3000 is inverter power.
This week I tried running our juicer off of our inverter, same model Xantrex 1500w that my dad has. It only works on the outlet closest to the inline transfer relay/inverter. On any of the other 110V outlets it just buzzes when you turn the switch on (and there is no amp draw). If I hook up shore power the juicer works flawless off any of the 110V outlets, so I don't think I have a wiring issue. There are 2 15A circuits, it doesn't work on either.
The inverter hasn't gone to sleep mode with the low draw becuase the TV still has power.
Why would the inverter only be able to power the juicer on 1 outlet?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
