otrfun's avatar
otrfun
Explorer II
Jul 20, 2013
Inverter Question
Searched various threads pertaining to "inverter installations". Obviously, the installs range from simple to elaborate.
The most simple seems to involve wiring an inverter to the battery and simply using 110v extension cords to directly power small applicances. Everything is functionally independent and separate from the TT's 110v outlets.
The most complex seem to have manual/auto switching of the entire TT to accommodate generator, shore, or inverter power.
I get the impression one moderately simple installation option could involve installing an inverter using heavy gauge wire connected to the battery. The inverter output could then be wired to an outlet somewhere outside the TT---in a convenient location that would allow the TT's main power cord to be easily connected. Of course, you couldn't power the a/c, and you'd want to make sure the converter is off, and the frig and water heater is on gas.
Assuming the worst:
1) I assume attempting to power the a/c (or any high amp device) would cause the inverter to simply overload and shut down with no damage to anything, right?
2) Do you risk damaging the converter or inverter if you accidently plug the TT's main power cord into the inverter with the converter still turned on? Since the converter would be attempting to charge the very same battery the inverter is using to power the converter---seems like a potentially vicious loop that could cause some damage. Does the potential for damage exist in this scenario?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
