RognBon
Aug 17, 2013Explorer
There are two positions on the fan control. One is on and one is automatic. You can turn the fan on, or you can set the control switch to auto and set the thermostat to the desired temperature inside the coach and when that temperature is reached the fan will turn on. It will then exhaust the warm air until a lower temperature is reached and will then turn off. Works just like a whole house fan or attic fan on a house.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
