Itinerant1 wrote:
That's because I'm living off my system and don't have the time to be a weekend worrior scientist making graphs, there is recorded data that time after time shows the same thing after 6 years of everyday use and many cycles in whatever SOC using high draw item for long periods. It works what I'm doing.
I find these threads amusing when everyone is bringing in different beliefs from different websites or blogs or sales page's.
I know one thing for sure, right or wrong, which I believe is good enough for "my" prupose of living off of solar/ lfp batteries with solar being the main charging source. 14.1v absorb 10 minutes tops but 6 minutes is usally when it switches to flaot at 13.6v. I have constant draws of 2ah from inverter (never turned off) and a humidifier 7ah on 24/7, total of 9ah always drawing then add in all the other comforts of life. I don’t scimp on power, some might even say wasteful but it's there to waste without worry. ;)
Pretty much..Even though I am not living off grid as I did for years in fifth wheels/motorhomes and travel trailers now,I run my TC 24/7 as if I was using battery power and solar connected to two 12v compressor fridges and occasional microwave use and lot's of TV/DVD use..
The reason for my questions or questions,is after a year using LFP as portable power stations in smart battery boxes,I decided to replace my house AGM with one of the LFP,which I just did a while back..I unhooked shore power and 100% on solar with an extension cord ran in for the little heater I use when it is cold..
I haven't hooked up the shore power to the system yet because of the old converter I have and screwing up my alternator maybe..It will work but not just as well as a proper one for LFP..I plan on disconnecting the charge wire to the lance camper and just use solar and portable chargers to keep them up without worry of my alternator if rumors are correct about the damage LFP can cause...
If you don't ask a question you will be guessing,so I ask here knowing there is some real LFP knowledge here as stated above..
Thanks for the answers,much appreciated..
