2oldman wrote:
hbski wrote:
but not sure I want to go 24V for the house batts. If I use the inverter just as an AC source than this is a moot point.
My goals are to be able to ... run the AC off of a 2k inverter genny (honda or yamaha)
I do 24v, no problem. Just need a small dc-dc converter for the 12v side.
If it does work at all, it's too much for a 2kw gen to handle for very long. And it will be loud.
HA...no way as loud as my ridiculously loud Onan...that thing is a beast....my portable champion 3500watt gas generator is quieter!!!
Sooooo, thinkin' about this some more the charger MUST only use what is available because you can set the input AC limit on both the Victron and the Magnum
