Smitty77's avatar
Smitty77
Magnum MS2812 'Absorb Done' settings
Hi All,
I've my replacement X's 4 Lifeline L16's installed in the coach.
Lifeline has been just top notch to work with during this adventure. And are doing sort of a post mortem on my old bank - expect to find I heavily sulfated them. Regardless, good not have worked with a business that cares more about helping a customer. Helping learn what they can do better the next time around. As well as helping me on the replacement of the slightly out of warranty bank. Salute!!
Recapping on my previous battery bank. I'd lived off of SOC the full time I had the bank. Using the MS2812's Efficiency Setting of 'Auto'. With periodic 'reset' when I knew the battery bank was fully recharged (Well should say 'thought' the bank was fully charged.)
It's been suggested to me in various threads, that using SOC may not be the best way to determine when the battery bank is fully charged. It's one of the tools in the tool box, but should be used/crossed referenced with other measurements too.
My question. The MS2812 Control Panel has 'Absorb Done' settings of SOC, Time or Amps.
I'd changed this setting to Time of 3 Hrs about three weeks ago. But with the new bank, I'm reviewing all settings again.
Since Lifeline's Tech Manual indicates my battery bank will be Fully Charged when Ending Amps reach 4 Amps (800AH's X .05%) - I'm wondering why not setting the 'Absorb Done' to Amps and a value of 4 Amps is not a better way to go then Time?
Would appreciate any opinions or input on this...
Also, as info, below are some of my other related charge settings.
Best to all,
Smitty
(MS2812; BMK Meter; SBC; AGS; Temp Sensor. Solar 1200W 48V; MidNite Classic150 Controller; WhzBngJr; Temp Sensor (After going thru a re-review of the Magnum settings. I'll walk thru the Classic's again too.) All feeding the care of 800AH House and X's 1 Lifelike 8D Chassis.)
Other Charger Settings, as of now:
-Absorb = 14.4V
-Float = 13.4V
-Equalize = 15.4V
-Max Charge = 100%
-Absorb Done = 3Hrs (Time) (May change to Amps = 4A)
-Max Charge Time = 12 Hrs
-Final Charge = Multi
-Charge Efficiency = 92% (For the first few charges of this bank. Once a few cycles of discharge/full recharge are complete - will set to 'Auto')
-SOC Reset (Plan to Reset Quarterly, once I've confirmed Full Charge vs Voltage Readings. This will be a rested non load battery reading with my multi meter.)
  • Turned off Magnum charger. 1.6 amps @ 14.2 volts from Blue Sky with float light flashing. Plugged in for 7 days. 556 amp-hours of battery bank.
  • Amazing how in the quest for automatic, function is compromised to the degree it is.
    Unless the magnum has its own amperage measuring device, seeing what the battery is accepting, then end amps can never be programmed correctly as any loads on the battery will throw it off.
    My manual adjustable voltage charger becomes more and more simple. Watch ammeter, twist dial accordingly.
    I also do not see any possible use for a charger, which is completely guessing as to state of charge, allowing the option to stop charging at anythig other than what it tinks is 1005 state of charge.
    gee, no, 92% is just fine, stop charging there.
    I don't know how you are going to achieve it, but if you want these batteries to get fully charged, hold absorption voltage until amps INTO the 800 AH of batteries, tapers to 4.
  • Yes, use the amps. With AGMs you leave the charger at Vabs (by battery spec) until amps taper down to near zip, then go to Float. Time to get to there is a variable, doesn't matter how long it takes.
    If you set the amps higher to account for loads, then it will be set too high if the loads are not on. If loads will usually screw things up at that point, you could split the bank and finish half properly while the other half does the loads, then swap. Once both halves done, you can go to Float on all. (Maybe have one of those "1,2, Both" switches in the set-up?)
    You need to add the parasitic draw to the 4A. E.g., if you run a satellite receiver that draws 3A while charging, your charge cutoff would be 4+3=7A. I wonder how long that would go on charging.
    HTH;
    John
  • I did not worry about amperage. I did reset voltage to the middle of what the surplus acid telecom jars recommend. I do have the temperature compensation probe and two nights ago voltage got to 15.5 due to cold weather.
    Occasionally, when the battery bank was "hungry" I've had to limit charge amperage to 108.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
