landyacht318
Oct 17, 2015Explorer
HECk, if you have the room inside the Borg for externally mounting a fan to the lid of the Megawatt, then do not limit yourself to a 60mm fan.
Not even sure why the lids are needed if they are inside another metal casing whose vents will be chickenwired to prevent debris intrusion.
Put a screened 120MM fan blowing in on Borg case(exterior?) and one 120MM sucking air out. This might negate the need for any internal fans which would be a PITA to replace, or hear if they get noisy.
I do have some ball bearing fans whose bearings make noise. They are better than sleeve bearing, but not bullettproof either
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
