MEXICOWANDERER's avatar
Oct 17, 2015
MEGAWATT Cooling Fan Questions
It's cooling fan modification time.
The louvered cutout on the aluminum case has 4 spot-welds in the hub. Any idea why?
I am planning on full-circle cut-out the holes on both Megawatts, then use coarse, very coarse, screen to deflect junk from falling in. Seems these fans throw a flow restriction hissy-fit at the first sign of obstruction.
Tomorrow is the start of final assembly. I picked up killer heat-sink blocks for the sides. And yes I will re-thermal-grease the bi-polar power transistors.
There's going to be a lot of "stuff" inside that old Sola case. So much so that I am going to have to use 16-gauge wire on the high voltage from the terminal block. But I have a Huey-grade aux cooling fan inside and that'll have to do... (or not).
  • Perhaps the spot welds are not that, and just marks from the stamping machine that punched out the holes for the fan's flow.
    These fans do poorly with a restriction behind the impeller. I know room is tight but they will move a lot more air if you place them on the outside of the casing with no restriction behind.
    Did you get 60mm ball bearing fans to replace the junky sleeve bearing fan provided?
    The hole needed for least restriction, is not round.
    From my Cheapowatt, may its rest in smoky fried pieces.
    That 60mm Noctua fan is now on my Meanwell's Lid blowing inward, along with a 80MM fan sucking air outward, and the stock 40MM fan Meanwell provided.
    Glad you did not want my heatsinks, as I am using them for a lighting project with halogen bulbs, but I woulda liked to meet you in person.
  • I am confused, perhaps a picture of the fans or a link to where to buy them would help grasp what they look like.
    But I trust that you know what you are talking about, and will get it done and make it better than stock.. .
    Fred.
