Toogreys's avatar
Toogreys
Need Help! Coach wont restart!
All, Need some assistance. I have Good Sams roadside assistance but hope its an easy fix.
We are on the road visiting realitives. Needed to get some more propane since we are up north and started up the coach to pull in the sideouts. The bedroom one seemed to come in just fine. The large living room one seemed to come in ok but there seems to be a larger gap at the bottom along the floor than normal but if you look at the end of the slide behind the drivers seat it looks like its seated ok. Pulled it in and out a couple times. Looked out side and the slide appears to be sealed ok and flush with the outer wall of the RV.
Turned off the coach and was about to get off when I thought while I was inside I might as well raise the jacks. Put the key in the ignition and it wouldnt start. All gauges etc work so dont think its the battery. Nothing happens when I turn the key. No clicking Nada.... Was wondring if its some sort of saftey lock out that needs to be reset or I blew a fuse or relay or something. I checked what fuses I could think of and they appear to be ok.
This is a 2003 Southwind with a 8.1 Workhorse gas engine.
Any sugestions before I call in the Goodsams Roadside assistance would be greatly appreciated!
Thanks
Stan
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jul 23, 2025
