mikestock's avatar
mikestock
Need help with a SF 30 Suburban Furnace
My original problem was the usual story. The fan would come on and the furnace would fail to light and the fan would then shut down. I, standing outside could hear the switch and smell gas but the spark, I couldn't hear due to fan noise and it was failing to light the gas. I brought the furnace home and checked the over-temperature thermostat and sail switch. They were good. I hooked up a 12 volt battery and opened up the combustion chamber to check to see if I was getting a good spark, which I was.
Took it back and reinstalled it and the fan no longer came on when I called for gas heat. I could, however, use the external 12v battery to supply power through the green and yellow wires while jumping the two blue wires together. With the gas hooked up, the furnace came on and burned, just like it should. I had the internal thermostat out of the circuit and the only hook up to the rv was the gas source. I hooked internal wires back, just like they were originally but nothing would happen.
I'm guessing that I have a thermostat problem. I may have caused it when I back fed power by accident, blowing the 2 amp glass fuse in the thermostat.
Lacking any expert suggestions I guess I will go spend $80 for a replacement thermostat. This one is a 3 way, AC, heat pump or gas furnace. The ac and heat pump functions still work.
Having RV issues? Connect with others who have been in your shoes.24,292 PostsLatest Activity: Jul 31, 2025
