maillemaker's avatar
maillemaker
Need to replace my water pump
My water pump has started leaking. It was made in 08/1990, so it's probably time.
The original pump was a Shurflow 2088-403-144. This is a 3-chamber pump that shuts off at 45 PSI and does 2.8 GPM and draws 4.6 amps max.
http://www.fourwh.com/2088-403-144.pdf
I emailed Shurflow and they recommended:
4008-101-E65
http://www.campingworld.com/shopping/item/shurflo-revolution-water-pump/49007
This is a 4-chamber pump that shuts off at 55 PSI and does 3 GPM and draws 7 amps max.
This is an old RV and I don't want to stress the plumbing system by increasing the PSI, nor do I need increased power draw.
I've emailed Shurflow back to confirm their recommendation.
What do you all think?
This looks like a better match to me?
https://www.freshwatersystems.com/specifications/2088-554-144.pdf
Steve
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
