shane102's avatar
shane102
new power max converter, problems
Replaced wfco 8955 converter with power max pm4b-55-mba converter. I put the new PM in today and followed the testing directions.
Step 1. With only shore power hooked up and all DC fuses pulled and battery disconnected (No load): voltage reads 14.74 on output side and no noise from converter. Directions say it should read 13.6 +/- .2
Step 2. with fuses in and battery hooked up and shore power on: voltage reads 12.54 on output side and the converter starts humming. Nothing in rv is turned on. Voltage at batteries read 12.54. Directions say voltage should be the same or close.
shut down all power at this time.
Voltage at disconnected batteries read 12.48.
first question is: the PM converter wires that hook to output side of fuse panel (DC side) are white and blue and both are 10 awg. I hooked blue wire to positive connector and white to negative. Is that correct?
Not sure why at step 1 the voltage is reading 14.74 with zero load? And not sure why at step 2 the converter is humming with nothing on?
I will be calling best converters in mourning. Any help, please.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Sep 14, 2014
