chefdc1
Nov 12, 2016Explorer
No 12 volt power after disconncting coach battery
I recently disconnected my coach battery to check for water levels and no longer have 12 v power. I forgot to disconnect shore power before doing this. All of the fuses are okay and everything works with shore power or with the generator running. Battery checks out to 12V. Any ideas...I'm stumped.
Also: this is a 1997 Damon Hornet Calss C, there is no battery by pass switch...no inverter. Very simple: 1 12v Battery, converter.
Okay, Red Wire and Black Wire (with fuse in line) are connected to Positive. Green is connected to negative. I had the black (with fuse) connected to negative (I didn't remember where the wire went when I first disconnectd (I know...I'm a bit of an idiot!). Now the panel lights come on showing battery power (tank levels etc), but still no 12v power to lights, pump etc. I rechecked all fuses...no issues.
Battery does not seem to be charging from shore power.
Pleas tell me I did not fry my converter!!
