I went through and examined some of the vacuum cords coming out of the back of the heater and didn't see anything that looked problematic. I couldn't find an inline fuse on the wire going to the fan motor. Would this be near the controls or near the motor? My next step will be to check voltage at the fan motor plugin when I get a voltmeter there.
Below is a picture of the wiring behind the controls. The one blue wire at the top is disconnected from something (not sure what) but it has a connector on it. And there is a non matching green wire seen just below it that is not connected to anything (difficult to see the connector at the top right of the picture). If you put those together, it blows the fuse that says "Heater" on it. Other than that, I'm not finding any terminals that look disconnected or problematic from the back of the control unit.
