Joeycockerspani's avatar
Jan 21, 2018
No Power to Dash/Chassis
So I go out to crank my motorhome. Batteries are fine. House power is fine. Everything works on the house side. But I have no voltage to the power distribution box located under the driver area. Consequently, nothing related to dash features shows any signs of life. Turn the ignition key, nothing. No gauges come to life, no buzzers, no power to the radio. Nada, zip, nothing. We have had this coach for over a decade. We have had many little glitches to work through. But this one is a first. Anyone out there have an idea?
Coach: 2006 Forest River Charleston
Chassis: Feightliner
  • Gdetrailer wrote:
    DiskDoctr wrote:
    Gdetrailer wrote:
    Why don't you simply buy a "battery maintainer"?
    An isolator is designed to allow charge to flow from alternator or converter/charger (later powered by shore power or generator) to BOTH the motor battery and the house battery.
    But it also allows ONLY the house battery to flow back to power the "RV parts" thereby leaving the motor battery to start the motorhome- even when the house battery is dead.
    Sometimes there is a "combine" switch to allow house battery to aid in boosting the motor battery to start in the event of emergency (dead battery).
    If the isolator was bad, the converter/charger cannot charge the motor battery, allowing it to slowly lose its charge to parasitic or standby losses.
    Wrong.
    There are TWO "types" of isolators..
    Smart and non-smart.
    Non-smart are the STANDARD ISSUE version which allows the vehicles alternator to charge both the starting battery AND the house battery. Acts like a one way valve and does not allow the house converter or batteries to "charge" the starting battery.
    DOES NOT PROVIDE EMERGENCY START OR COMBINE OF THE BATTERIES.
    Smart isolators on the other hand, can allow the house battery/converter to trickle charge the vehicle battery.
    Also provides EMERGENCY STARTING WHICH COMBINES BATTERIES FOR A FEW SECONDS.
    The OP obviously does not have a smart isolator or they could have simply pushed the EMERGENCY COMBINE BUTTON to get the engine started.
    It's quite obvious which one I described. I've also seen diodes added to simple isolators to allow charging from the genny/converter.
    BTW, starting a post with "Wrong" is not only combative, in this case it is also incorrect ;)
  • I tried to find one that looks like this that is considered "continuous duty" but failed. I have to assssssume the one pictured is a starter motor use relay. Maybe 1.2 ohms resistance across the magnetic coil.
    If this rig is a pusher diesel with larger than a seven liter diesel engine, it would require an expensive relay like this to power the jump start which can range to 500+ amps and even more than that in cold weather.
    This is an image of a 200-amp bi-directional SMART relay which would pass the power of all but the largest alternators.
    With a 7.0+ liter diesel engine I would not elect to use the "feature" of this smart relay to jump start from bank to bank. I would retain the relay what is featured in this thread. Two relays each best suited for it's purpose.
    By selecting the BI-Directional model relay the relay will operate and pass current no matter which direction the power is coming from -- alternator or converter. This keeps chassis and hotel batteries happy.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
