kmb1966's avatar
kmb1966
Norcold 1200 Thermistor reads wrong until door opened/closed
I have a Norcold 1200 with a strange problem. The cooling unit will operate and cool down to around 35 degrees (or slightly lower) and work fine for about a week. Then suddenly the temperature inside will start climbing and get into the mid 50's and the cooling unit will not engage because the thermistor temperature reads 15 degrees (using the diagnostic mode). Upon opening the door (light comes on) the thermistor temperature will jump to 10 degrees. If I toggle the door switch (causing the light to go off and back on) (either door), the thermistor will suddenly switch to reading 45 degrees and the cooling unit will come on. I've changed the thermistor, I've checked the connector plug (playing with the connector plug has no effect when the thermistor is reading incorrectly). Problem persists. Only opening and closing either door will cause the thermistor to snap out of it's problem and read correctly, and therefore cause the cooling unit to operate correctly. :h
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 15, 2025
