pcm1959's avatar
pcm1959
Explorer II
Jul 06, 2014
Norcold 1210 cooling during Travel
Ok, just returned home from another weekend trip with my new Lifestyle LS36fw fifth wheel with a Norcold double door 1210 fridge. It still cools poorly during travel. Initially I thought it was a door leak due to the poor design of the latches. I did make some adjustments to the doors/latches and while it did not help the cooling issue, they do open and close much, much more tightly and easily now. This has not made any difference to the cooling, however.
As always, the fridge is precooled to 37 degrees on LP, stocked (not overloaded) with ALL pre-cooled items. By the time we started the 90 minute trip, weather moved in and the outside temps dropped to 73 degrees. Despite that, the fridge temp gradually climbed to 50 degrees during our 90 minute trip. The burner was burning strong, no error messages, etc. The unit precools great on LP prior to a trip, cools great while at our destination running on a/c OR LP, and then warms back-up again on the journey home.
This is the case on a 90 minute trip OR a 7 hour trip. In fact in May, the temp was nearly 60 degrees during a 6 hour trip. I cannot get the fridge to maintain a safe temperature during travel. Originally, I thought that is was a door leak but I'm sure that is not longer a possibility. I thought maybe it was a wind turbulence issue down the sidewall but I am leaning away from that, as well.
I have even made sure that both roof vents are closed during travel just to make sure there is not some type of venturi effect on the fridge.
The rig tows perfectly level, too.
I can't imagine taking it to the dealer as they are not going to tow it around to duplicate the problem and it cools fine while parked.
If anyone has any suggestion, please advise. Thanks! Phillip
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
