workinman's avatar
workinman
Norcold 1210 IM Blows 5 amp fuse
I replace the cooling unit on my Norcold 1210 IM..... everything went fine. Unit worked great. The outside temp dropped below freezing, Ice maker line broke spraying water all over the motherboard tripping the 30 amp AC circuit breaker. Reset breaker. I could not get the unit to work. I replaced the motherboard. Everything went fine. Unit worked great. Almost too great. I had to turn the setting down to 1 to keep the milk from freezing. Blew the 5 am DC fuse a couple of weeks later. Replace it. Unit worked fine. Same fuse blew a few weeks later. Replaced it. Unit worked fine. Now, a few weeks later, the fuse has blown again. I cannot put another fuse in without it blowing immediately. Help? Thank you!
  • Old-Biscuit wrote:
    If it is 5 A (tan color),automotive blade style, it is for the 12V DC control circuit.
    The 120V AC heating element is an 8 A, AGC style, fast acting fuse
    The 5A blowing could be loose or damaged terminals at wire harness connector or circuit board connector
    OR could be Fault in Optical Control Display overlay.
    You will need to do a complete voltage check/test to ID problem.
    Here is a service manual...pg. 12 has flow chart/tests for the 5A DC fuse circuit
    LINK
    Thanks Old-Biscuit for the clarification. I was just shooting from the hip without doing any research.
    Keep up the good work.
    Jerry Parr
  • If it is 5 A (tan color),automotive blade style, it is for the 12V DC control circuit.
    LINK
  • Maybe so..... those are new as well..... I have rebuilt the whole thing.....
