Shelborne's avatar
Shelborne
Norcold N621 Refrigerator/Freezer not working--'07 Nash 17C
Hello everyone,
I have a Norcold N621 (N621L) refrigerator/freezer unit that is not working. There are no error codes. Everything looks perfectly normal on the panel. I have plenty of propane in the tanks, and my batteries are fully charged. The trailer has hardly been used, probably 6/7 times or so, with only a two days on each trip.
I've never had a problem with the unit until this morning when I woke up and opened the refrigerator and freezer. All of the frozen was thawed, and the refrigerator wasn't producing cold air either.
I have turned the unit off/on multiple times, disconnected the battery....waited about 10 minutes hoping that it would cycle the power on the refrigerator... still nothing.
I have gone through the manual, but everything else points to error codes which my refrigerator/freezer does not have.
Every time I turn unit off and then back on I hear a clicking sound which indicates that it is firing. However, as I indicated earlier, it simply does not produce cold air.
The propane heater works, as does the stove, and my hot water heater. All of the propane appliances work in this trailer except for the refrigerator/freezer.
I haven't had a chance to test The refrigerator/freezer with any other method of power like a generator or shore power...just propane. This particular refrigerator/freezer has an auto sensor and it picks up the propane with no problem...
I power the unit on, press the mode to Auto, it auto senses the propane, makes a little clicking sound as usual and then nothing. All appears normal, just no cold air.
I tried bypassing the auto sensor mode on the unit and just manually chose LP, but still no cold air coming from the fins in the refrigerator or the back of the freezer. No noise.... just silence. I can't remember if the unit made any noise in the past, but if it did it was extremely minimal and I didn't remember it.
There are no smells coming from the unit indicating that there might be a problem with the coolant... etc....and I've gone on various forms and can't find anything amiss.
Again, everything appears to be completely normal, just no cold air.
Does anybody here on the forum have any suggestions, or ideas?
Thank you very much!
Sent from my iPhone
