USMA_Dad
Sep 03, 2018Explorer
Itinerant1 wrote:
If you don't have the service manual (google and download it) that has step by step for troubleshooting (you'll need a multimeter) that will eliminate any doubts of eyebrow board/ power board, thermistor, heating elements.
I just went through this with my N821 same thing no faults except for a '0' on the eyebrow display. No where could I find what it meant but after a bunch of internet searching found it was for the high temperature limit switch (on the exhaust tube) locked out the controls to turn the fridge on propane or electric. Disconnecting the 2 wires from the limit switch and used a jumper to bypass it, the fridge would turn on and run. *Do not run fridge like this it's a safety feature to shut down before a possible fire*. Waiting for new switch to arrive.
After pulling fridge out of cubby the heat shield that goes over the exhaust pipe slide down and started to block the tube.
I found the service manual and will go through the troubleshooting steps. Thanks.
I don't think it's the high limit switch since the Condensers are getting hot. That tells me the heating unit is working, plus the canister is hot to the touch. As mentioned below, I think I'll try the rubber hammer for a while. The trailer is level and everything was fine for months...until last Wednesday.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
