dougrainer
Sep 03, 2018Nomad
USMA Dad wrote:
I've searched for the fan and do not see it. According to the service model, my model (n811L) does not have a fan installed. Hopefully, Jayco installed the fan kit; however, again, I don't see it. I'm heading out again to search.
I've tapped on the condenser tubes/fins with a rubber mallet so we'll see if that helps. The Absorber tubes are still cold to the touch. In fact, see the picture for the condenser tubes' temps. it's strange the are not the same. Tube on the left runs down to the Absorber tubes and it is cold as well.
YOU said you had fans. Regardless, IN a slide room and no fans the refer will NOT operate to spec. Take a small fan and remove the upper outside door and have that fan blowing OUT and see what happens after 24 hours. BURPING WILL NOT FIX ANYTHING, IT IS A OLD WIVES TALE. if you "think" you have an air blockage(never heard of such a thing), just turn the refer off for 24 hours and restart. Your model has a NO CO fault system. NO CO means NO COOL and will trip a code and shut the refer off. As you have found out, replacing parts does not always fix problems. WHY did you replace the 5 amp fuse? What caused it to fail? Which fuse? The 12 volt power supply fuse on the module or the fuse for the 120 heating element? Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
