enblethen
Jul 03, 2017Nomad
A clogged stack.
The stack is right above the flame. It is about 3/4 inch diameter pipe. There is a baffle about 4-5 inches up inside.
Use a stiff but slightly flexible peice of wire. Push it up into the stack to knock loose carbon build up.
Make sure unit is off!
Be prepared for carbon to fall down. Vacuum out debris.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
