merc1100sc's avatar
merc1100sc
Pair of Yam EF2000is to run roof AC?
I know similar questions have been asked over and over again. Mostly about running an AC off one 2000 watt unit.
I have a 28' work and play with a rooftop unit. Not exactly sure of the AC specs. I have two Yamaha EF2000is inverter generators that I plan to use to power the camper. Will these two, bridged together, run the AC, lights, etc. with causing harm to the generators or any any electrical components?
Thanks.
    Be aware that the Yamaha EF2000iS doesn't play well with any Progressive Industries EMS as detailed in this disclaimer so if you're protecting your rig with one of these units you'd want to remove it from the circuit before powering your rig with these gensets. Can't say whether Yamaha has solved this issue with their newest version of this genset, the EF2000iSv2. If you don't use an EMS while running on shore power (a mistake IMO) then this wouldn't be an issue for you.
  • Well assuming your RV is not more than 30 amp, and the yamaha's can be paralleled, and the generators are rated for 1800 watts each continuous, then yes.
