mena661's avatar
mena661
Panel to Solar Controller Wire Size
As some of you already know, I'm piecing together a solar system. Controller is a Morningstar 45A PWM. Panels will be two 12V 150W wired in parallel. I'm going to be using a combiner box on the roof, more than likely the AM Solar one that "connects" to the fridge vent. Basically, the panel wires will connect to the C-Box and then I want two wires from there to the controller. I estimate 15 feet for that run but might be longer. I intend to buy 25 ft of wire. I think that should do it. Considering getting this: Genuinedealz Flat Duplex Marine. Not sure what size wiring to get. My confusion is in how much voltage drop is ok. Needs to accommodate up to 450W in parallel total. Thanks all.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
