DryCamper11's avatar
DryCamper11
PD or Iota for my upgrade?
I'm thinking about a converter and battery upgrade. The batteries will be wet cell lead acid 6 volt Possible T-105s or the 230AH, EGC2 from Sam's club. I'll probably go for four. (Does nayone have recommended charging specs for the Sam's Club? The Trojan calls for 14.8 volts)
The converter will be installed within 3' of the batteries with 1/0 cable. I'd like to optimize charge speed with my Onan CCK generator. I'll probably buy a Trimetric 2025. I don't have solar, but may consider it later.
I'm leaning toward the PD9280 for these reasons:
1)The Charge Wizard lets me put it into boost mode or float mode. I like having control.
2)The Charge wizard is really simple - a single LED and a switch. I can integrate it into my existing control system and install one near the batteries and another near the monitoring station where my voltage monitor is now and the 2025 will be.
3) The patents for the PD 9200 series are extremely specific about circuit construction. There's enough there for repair or modification, which I'm interested in doing.
4) The design of the PD 9200 series makes sense to me from the patents and seems to be easy to control/modify. It uses the Unitrode UC3846 PWM current mode chip at its heart, which provides both constant current and constant voltage control on a pulse-by-pulse basis. It looks like it would be easy to change the current limit or the voltage output with a single resistor. I've read the patents several times.
On the down side, I know nothing about how the PD 9200 series converter performs, other than what I've read here (which is a lot, but I'm still working through it all). I've seen claims here that the Iota will perform better for fast charge from a generator when heavy cables are used and that the PD has a "bad design,", but I can't figure out why that opinion was expressed or what the design of the Iota is.
I know almost nothing about the design of the Iota, except that the boost/bulk mode voltage is higher. It looks like that voltage would be easy to adjust on the PD9200. It should be possible to adjust output voltage based on battery temp also. I'd love to know if anyone has modified the PD9200 series or if there is comparable information about the design of the Iota (a circuit diagram?).
I know there are more expensive converters that offer some of these features, but cost is important.
From some threads I've read, there can be dispute over the relative merits of these converters. I'm not looking for anything but friendly information.
Thanks for any comments or information you have.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 23, 2025
